gkket 发表于 2020-11-25 20:55:25
PLC编程英语,自动化专业英语大全~你认识几个?
https://mmbiz.qpic.cn/mmbiz_jpg/RsvL41ewpMnefJQDyOauWqDFMxr12ianvzCDc6WnsDfUxSZtiaMqc0CGcRhuKvFp4zvCg9pC4EG67W4gspFhbkFw/640?wx_fmt=jpeg
1. PLC 可编程控制器
2. absolute绝对 3. absoluteoutput   绝对最大输出
4 .actuator执行器
5. against对比
6. allocate分配
7. alter改变修改
8. ambient环境 周围 ambient operating temperature
9. analog 模拟   analogoutput
10. analysis 分析 thecollection an and analysis of data
12. applicable 可用the applicableCPU for the module
13.assign 分配
14.back up battey备用电池
15.barcode reader/ID条形码阅读器
16.base unit主基板
17.baud 波特
18. beforehand事先
19 .binary 二进制
20.buffer memory 缓冲存储器
21. bus 总线
22. case 外壳 do notremove the module's print board from the case
23. characteristic 特征 I/Ocharacterristic
24. check 校验 the datalink status canbe checked
25. child-station子站
26. common terminal   公共端
27. compatible兼容 compatiblewith the MODBUS protocol
28. compound混合compoundsystem communication [`compaund]
29. condensation结露
30. condition   条件 conditionsetting
31. conductive导电 conductivemetal picees
32. configuration组态 systemconfiguration
33. configure组态
34. confirm确认 how toconfirm the operation of the module
35. consumption消耗 currentconsumption
36. content目录
37. control level控制级
38. convenient 方便 moreconvenient and easy-to-use
39. conventionaly传统 whichconventionaly has been used
40. conversion 转换 Analog-Digital conversion module
41. converter转换器
42. conveyor传送 conveyorline
43. corrosive腐蚀 corrosivegas
44. countermeasure对策countermeasure for mis-inpute
45. cutoff切断
46. debug调试 isrecommended before debugging
47. dedicated屏蔽 cc-linkdedicated cable
48. dedicated专用 dedicatedtransmission protocol
49. default value缺省值
50. define解释 阐明 Offset value and gain value are defined as follow.
51. design设计 design asystem
52. device level现场级
53. diagnosis诊断 diagnosisfunction
54. digital数字digitalinpute
55. DIN rail导轨
56. diverse不同的各种各样的
57. download下载
58. duplicate完全一样https://mmbiz.qpic.cn/mmbiz_jpg/RsvL41ewpMnbx0RR8wSaBB3D6rKb7e7aP3CSN1m7LQXBGbYVn1RcicayFHTayQaNepO3OBINiaN9Xc3Eib1nBKElQ/640?wx_fmt=jpeg59. dust灰尘
60. eliminate免得
61. enterprise level管理级
62. erase清除
63. exceed超出 The numberadmitted must not exceed 200
64. execute执行 date linkis executed using these parameters
65. expand扩展 can beeapanded up to 255 networks
66. faulty 故 障站
67. field bus现场总线
68. fix固定
69. flexibly灵活的 to supporta variety systerm flexibly
70. flow流量
71. format格式transmission format [`fo:maet]
72. fuse   融丝
73. graph图标 坐标图曲线图 voltage output characterristicgraph
74. guaranteed担保 nomaloperration cannot be guaranteed
75. handle处理
76. hardware manual硬件手册
77. hint提示 programminghints
78. humidity湿度 ambientoperating humdlity
79. individual独立的
80. inductance电感 inductanceload
81. initiate实施 发起 can be initiate by a computer
82. input输入
83. input point输入点数
84. install安装
85. instruction指令 the FROMinstruction
86. insulation 隔离 form rubberprovides good insulation [,insju`leifn]
87. interface接口
88. interlocking互锁 can be usedfor sequence program interlocking
89. internal external内部 外部 internal connection
90. interrupt中断 excute aninterrupt processing
91. invalid 无效 errorinvalid station function
92. magnetic 有磁性的 magneticfields
93. main circuit主回路
94. malfunction故障 causesystem malfunction
95. mandatory强制
96. mantenance维护 maintenancecosts are reduced
97. manual手册 User'Manual
98. mechanical机械 michanicallife机械寿命
99. module模块 mount orremove the module [`modju:l]
100. momentary power failure瞬时断电
101. monitor监视
102. mount固定 mount orremove the module
103. multiple多样 mutipleremote i/o modules
104. negative负
105. observation 观察
106. occupy占用 occupies 1station
107. occur发生
108. offline离线 offlinetest
109. offset gain偏置增益
110. oil mist油雾
112. optical loop光缆回路
113. optimum最佳的 optimumcontrol
114. output输出
115. overall总的 overalldistance
116. overview总揽communication overview
117. parameter参数
118. path路径transmission path
119. per network
120. perform进行 normal datalink cannot be performed
121. performance specifations性能规格
122. peripheral外围 Whenutilizing peripheral device to assign I/O number.
123. phase 相 swith offall phases of the power supply [`feiz]
124. point要点
125. port 接口Rs232c port
126. positive正
127.power line 电源线
128. power on/off上电断电
129. precaution注意事项precaution when configuing system
130. print board印刷电路板
131. procedure过程 follow theprocedure
132. programing interface编程口
133. protocol协议 protocolcommunication issues
134. range范围
135. rated input voltage额定输入电压
136. ratio比率
137. recommend建议 isrecommended before debugging
138. reduce减少 the numberof steps in operation program can be reduced
139. refer to参照 refer toChapter 6
140. register数据寄存器
141. relay继电器 [`ri:lei]
142. remote I/O 远程网络
143. reserved station 预留主站
144. resistor电阻 resistorload阻性负载   terminating resistor
145. resolution分解,解析 nMaximum resolution   最大分辨率
146. restriction限制 norestriction
147. retry 重试
148. scan 扫描 link scan
149. screw 螺丝 Teminal-block screw
150. seamless network 无缝网络
151. sequence programme 顺控程序
152. serial communications module 串口模块
153. series 系列
154. servo 伺服
155. short 短路
156. signal 信号
157. sink 漏极 sink commen
158. slot 槽
159. soures 源极 sourescommen
160. specifications 特性 inputmodules specifications
161. stabilized power supply 稳压电源
162. standby master station 备用主站
163. start up 起动
164. status 状态 data linkstatus
165. step drive 步进
166. storage 存储 storagearea
167. store 存储
168. switch off 关断 swith offall phases of the power supply
169. swith 开关
170. table 表格
171. transfer 传输
172. transistor 晶体管
173. transmission speed 传输速度
174. transmit 传送 data istransmitted in unchanged code
175. triac 双端三相可控硅开关
176. troubleshooting 故障处理
177. unuseble 不可以使用
178. upload 上传
179. utilize 利用 Whenutilizing peripheral device to assign I/O number.
180. verify 校验 verify theset parameter contents
181. voltage 电压 highvoltage
182. watchdog 看门狗
183. width 范围 it willvary in the width of
184.wire chips 线头
A朱金涛 发表于 2020-11-25 20:55:38
wx_T24982Z1 发表于 2020-11-26 00:34:51
372926198501293 发表于 2025-11-18 15:00:01
15547333755 发表于 2025-11-18 15:03:37
木云 发表于 2025-11-18 15:05:53
绿树银花 发表于 2025-11-18 15:07:50
禾急禾急 发表于 2025-11-18 15:09:19
13218607736 发表于 2025-11-18 15:11:09
wx_M2fqhEEU 发表于 2025-11-18 15:12:28
查看完整版本: PLC编程英语,自动化专业英语大全~你认识几个?
