gkket 发表于 2021-9-4 11:57:16
Winform 选择文件、文件夹、打开指定目录的方法
using System;
using System.Windows.Forms;
namespace WindowsFormsApp1
    public partial class Form1 : Form
      public Form1()
            InitializeComponent();
      /// <summary>
      /// 选择文件
      /// </summary>
      /// <param name="sender"></param>
      /// <param name="e"></param>
      private void button1_Click(object sender, EventArgs e)
            OpenFileDialog openFileDialog1 = new OpenFileDialog();
            openFileDialog1.Multiselect = true;
            openFileDialog1.Title = "请选择文件";
            openFileDialog1.Filter = "所有文件(*.*)|*.*";
            if (openFileDialog1.ShowDialog() == DialogResult.OK)
                string filename = openFileDialog1.FileName;
                MessageBox.Show("已选择文件:" + filename, "选择文件提示", MessageBoxButtons.OK, MessageBoxIcon.Information);
      /// <summary>
      /// 选择文件夹、路径
      /// </summary>
      private void button2_Click(object sender, EventArgs e)
            FolderBrowserDialog folderBrowserDialog1 = new FolderBrowserDialog();
            folderBrowserDialog1.Description = "请选择文件路径";
            if (folderBrowserDialog1.ShowDialog() == DialogResult.OK)
                string path = folderBrowserDialog1.SelectedPath;
                MessageBox.Show("已选择文件夹:" + path, "选择文件夹提示", MessageBoxButtons.OK, MessageBoxIcon.Information);
      /// <summary>
      /// 打开目录
      /// </summary>
      private void button3_Click(object sender, EventArgs e)
            System.Diagnostics.Process.Start("Explorer.exe", "C:\\Windows");
来源:C#社区
原文:https://www.hicsharp.com/a/56eb4f0c4f2c4b98af522634d2e1789c
li781388 发表于 2021-9-4 12:03:59
这个类目最活跃了!赞一个!
詹姆斯 发表于 2021-9-4 12:09:17
漠北 发表于 2025-11-17 09:31:23
mark_qM1gr 发表于 2025-11-17 09:42:26
@Xizi_yE0Mjfrw 发表于 2025-11-17 09:48:35
caixiaobao2020 发表于 2025-11-17 09:49:30
黎明 发表于 2025-11-17 09:51:09
zcx 发表于 2025-11-17 09:52:33
国栋_dFz8Z 发表于 2025-11-17 09:56:08
查看完整版本: Winform 选择文件、文件夹、打开指定目录的方法
