如何在WinCC画面中显示网页
第一步:(打开桌面上WINCC组态软件)https://p3-sign.toutiaoimg.com/pgc-image/950978155ce342ac99c7c8f44ef4c148~noop.image?_iz=58558&from=article.pc_detail&x-expires=1678926582&x-signature=cbZKr5djBcH7ohwNJKQwmV%2F9QAU%3D第二步:(打开后,在左侧菜单栏选择图形编辑器,然后创建一个新的过程画面)。https://p3-sign.toutiaoimg.com/pgc-image/a06e524df51a4e218b7cca06641d0f22~noop.image?_iz=58558&from=article.pc_detail&x-expires=1678926582&x-signature=NWa5n8SvWZfX8uR8wMj73n6J7z8%3D
第三步:(打开新创建的过程画面,在右侧控件菜单栏中选择WinCC WebBrowser Control,鼠标选中然后鼠标移动到中间画面当中点击创建显示成功)。https://p3-sign.toutiaoimg.com/pgc-image/5ee4d4c04f6148d9a14ed4c8e238b4e2~noop.image?_iz=58558&from=article.pc_detail&x-expires=1678926582&x-signature=NbiajXxH%2BWVWjXQamITXssTFjXo%3D
https://p3-sign.toutiaoimg.com/pgc-image/fb6b2aa51e0248a189dc338050de2432~noop.image?_iz=58558&from=article.pc_detail&x-expires=1678926582&x-signature=7UOkHjSJl7caAmoxHXeUErpfn60%3D
第四步:(鼠标右击打开WinCC WebBrowser Control属性)https://p3-sign.toutiaoimg.com/pgc-image/d618420fd69f4e058119bac2f3e6151c~noop.image?_iz=58558&from=article.pc_detail&x-expires=1678926582&x-signature=PGFHBUpmOdphXtBGhtgAkiMbpYU%3D
第五步:(对象属性—控件属性—属性MyPage—静态填写要显示的网页地址,比如这里,填写技成官网:www.jcpeixun.com)https://p3-sign.toutiaoimg.com/pgc-image/fe040a1f74f64a788a62ea69ad3ad63c~noop.image?_iz=58558&from=article.pc_detail&x-expires=1678926582&x-signature=bDQAcdtcQS8GcUtwDhAJrgBLPqI%3D
第六步:(回到画面当中,运行画面系统)https://p3-sign.toutiaoimg.com/pgc-image/10d77e1b1c7647b18965725628bf3858~noop.image?_iz=58558&from=article.pc_detail&x-expires=1678926582&x-signature=JA5nLJGsHVrg3gJHuZlU%2BrfOAyM%3D
https://p3-sign.toutiaoimg.com/pgc-image/dfd8ed1601d34d7ba21a3eda8083e97f~noop.image?_iz=58558&from=article.pc_detail&x-expires=1678926582&x-signature=p4h7RORDcGjKMd0DpUS%2BmSKCQy4%3D
第七步:(运行系统,看效果)。https://p3-sign.toutiaoimg.com/pgc-image/04a13a787de34580945c22c79e67f8d7~noop.image?_iz=58558&from=article.pc_detail&x-expires=1678926582&x-signature=2Wo1iGrQW2v90UNR8l9V4nrVMO4%3D
https://p3-sign.toutiaoimg.com/pgc-image/1563a4e3fa8f4643b51aa82f0af96618~noop.image?_iz=58558&from=article.pc_detail&x-expires=1678926582&x-signature=W%2By5OL0ZnrXhKLsKCsRlwwxZjfc%3D
来源:PLC发烧友,作者:技成培训网-徐陈爽,未经授权请勿转载!
强烈支持楼主ing…… 内容太顶了!疯狂点赞,已默默收藏~ 画面感太强了,仿佛身临其境! 同款经历!我当初也这么过来的😂 谁懂啊!这内容我能循环看十遍 救命!这波发言太秀了,直接原地封神~
疯狂认同!楼主说出了我不敢说的话 救命!这回复笑到我捶桌,必须置顶~ 蹲一波同款,有没有姐妹 / 兄弟推荐? 被戳中笑点 / 泪点,太真实了!
