一文了解发电机原理和结构
https://pic4.zhimg.com/80/v2-084a1636ee0bb2d9d303a88fac43ff01_hd.webp
https://pic2.zhimg.com/80/v2-81ddf58abbd435ce0e214116f37d5fb9_hd.webp
https://pic3.zhimg.com/80/v2-83122e294355e4843766bbec6b9503f7_hd.webp
https://pic4.zhimg.com/80/v2-51322fb6d7543521d8092bfd0cd937ee_hd.webp
https://pic4.zhimg.com/80/v2-303f96a2b12426a79ad622e8889876e6_hd.webp
https://pic4.zhimg.com/80/v2-efacd498c77d79f34ad950ac97e6f56d_hd.webp
https://pic2.zhimg.com/80/v2-8d47529765f5e334283f186200e6f218_hd.webp
https://pic2.zhimg.com/80/v2-06710492d4e09a6c61abed71709e633b_hd.webp
https://pic2.zhimg.com/80/v2-86ee910536382773299218c1e2d81511_hd.webp
https://pic4.zhimg.com/80/v2-73cf0e15536458e63b2ea6e2bd3ada68_hd.webp
https://pic1.zhimg.com/v2-3c40829a650f96ab57be6975d78f8601.jpg
https://pic4.zhimg.com/80/v2-0b537272bf3b40098726c8fb2f1743b9_hd.webp
https://pic3.zhimg.com/80/v2-4bd191034c7f4c6d8c22ca2f8557d047_hd.webp
https://pic1.zhimg.com/80/v2-d6415661273ee48f194f4a302a884b7b_hd.webp
https://pic1.zhimg.com/80/v2-f83293e31d45a47fd21762a1517119ee_hd.webp
https://pic1.zhimg.com/80/v2-85e16b3348f30ccc37e1607c15bd523b_hd.webp
https://pic4.zhimg.com/80/v2-a1ca33190e83a200303549cf74c6776b_hd.webp
https://pic4.zhimg.com/80/v2-d5640132dc07578a60e407021be3a24b_hd.webp
https://pic4.zhimg.com/80/v2-bba7b5ad2622053fbdf19ae8e49cf3ad_hd.webp
https://pic1.zhimg.com/80/v2-3ae82e871c4a0f0526af265a26f75ac8_hd.webp
https://pic4.zhimg.com/80/v2-9f516c8e442380b03720c0b792f72629_hd.webp
https://pic1.zhimg.com/80/v2-84ac65da2c6eb3c1afbfa787e8a9b9ab_hd.webp
https://pic4.zhimg.com/80/v2-c7c39a29cd7347796a3905587e784301_hd.webp
https://pic4.zhimg.com/80/v2-c1f59d48386487b6645d923e61cd618a_hd.webp
https://pic2.zhimg.com/80/v2-c20a48facf0e886519bfedbb2e32c2fb_hd.webp
https://pic1.zhimg.com/80/v2-afa2e2d05d4893ce207f32269bb561ad_hd.webp
https://pic4.zhimg.com/80/v2-2bb732462efde2a3287d5749c496bfbb_hd.webp
https://pic2.zhimg.com/80/v2-84eccc13acdedb6cd9f3b788636b2fc3_hd.webp
https://pic2.zhimg.com/80/v2-3e69a1920c1ca7c390f9196bfd32580d_hd.webp
https://pic1.zhimg.com/80/v2-d46dfa4829399d0bf36fa57d7d44f29c_hd.webp
https://pic3.zhimg.com/80/v2-8a45f0ac7aaae0473f29ee3f6c50480f_hd.webp
https://pic4.zhimg.com/80/v2-20376330666d8f71b1e06bd334b50ac2_hd.webp
4.1发电机安装交接试验
中华人民共和国国家标准GBGB 50150-2006 <<电气装置安装工程电气设备交接试验标准>>
1 定子绕组的绝缘电阻和吸收比或极化指数;
2 定子绕组的直流电阻;
3 定子绕组直流耐压试验和泄漏电流
4 定子绕组交流耐压试验;
5 转子绕组的绝缘电阻;
6 转子绕组的直流电阻;
7 转子绕组交流耐压试验;
8 发电机或励磁机的励磁回路连同所连接设备的绝缘电阻,不包括发电机转子和励磁机电枢;
9 发电机或励磁机的励磁回路连同所连接设备的交流耐压试验,不包括发电机转子和励磁机电枢;
10发电机、励磁机的绝缘轴承和转子进水支座的绝缘电阻;
11 埋入式测温计的检查;
12 灭磁电阻器、自同步电阻器的直流电阻;
13 转子绕组的交流阻抗和功率损耗(无刷励磁机组,无测量条件时,可以不测量);
14测录三相短路特性曲线;
15测录空载特性曲线;
16测量发电机定子开路时的灭磁时间常数和转子过电压倍数;
17测量发电机自动灭磁装置分闸后的定子残压;
18测量相序;
19测量轴电压;
20定子绕组端部固有振动频率测试及模态分析;
21定子绕组端部现包绝缘施加直流电压测量。
4.2定子直流耐压和泄露电流
在直流耐压试验过程中,可以从电压和电流的对应关系中观察绝缘状态,在大多数情况下,可以在绝缘尚未击穿前就能发现或找出缺陷,直流试验时,对发电机定子绕组绝缘是按照电阻分压的,因而能较交流耐压更有效地发现端部缺陷和间隙性缺陷,另外击穿时绝缘的损伤程度较小。
直流耐压试验的试验电压为3Un=72kV,各相泄漏电流值的差别不应大于最小值的100%,当最大泄漏电流值在20μA以下,各相差值与出厂试验值比较不应有明显差别
https://pic3.zhimg.com/80/v2-7c672e392a62a7240f752236a99773f7_hd.webp
4.3定子交流耐压试验
交流耐压试验电压和工作电压的波形、频率一致,作用于绝缘内部的电压分布及击穿性能能够适应发电机的工作状态,无论从劣化或热击穿的观点来看,交流耐压试验对发电机主绝缘是比较可靠的检查考验方法。
要求:
a 交流耐压试验电压为:(2Un+1000V)*0.8;
b 水内冷电机在通水情况下进行,水质应合格,氢冷电机必须在冲 氢前或排氢后且含氢量3%以下时进行试验,严禁在置换过程中进行。
https://pic3.zhimg.com/80/v2-c4ef9ff1e881063ba0d696880d80db85_hd.webp
https://pic3.zhimg.com/80/v2-babe7e52d6177756f94ad1470920b9c0_hd.webp
https://pic4.zhimg.com/80/v2-86ec48d37ed6c5c4d5cf5f444b5f6fe3_hd.webp
https://pic1.zhimg.com/80/v2-3ec97595ab6852771342ddba6f839db1_hd.webp
https://pic2.zhimg.com/80/v2-2bef444d9a5b2a6a4d03457c16eaff33_hd.webp
https://pic4.zhimg.com/80/v2-0157bc769ea8717b76a7df90d121ac24_hd.webp
https://pic4.zhimg.com/80/v2-c7c9aa4bda33a28347040c3fdb28e7e8_hd.webp
https://pic4.zhimg.com/80/v2-0ddbcce460128c2517863091487f018b_hd.webp
党的好公民,人民的好公仆。。。 好东西一定要看看! 真是难得给力的帖子啊。 真是难得给力的帖子啊。 看了楼主的帖子,不由得精神一振,豁然开朗,牛掰 无回帖,不论坛,这才是人道。 无私奉献,好工控人,32个赞送给你!! 绝对干货,楼主给力,支持了!!! 楼主您的技术水准,我最服你,其他都是浮云
