查看: 1969|回复: 12
Winform 选择文件、文件夹、打开指定目录的方法
发表于 2021-9-12 15:34:03 | 显示全部楼层 |阅读模式
  1. using System;
  2. using System.Windows.Forms;
  3. namespace WindowsFormsApp1
  4. {
  5.     public partial class Form1 : Form
  6.     {
  7.         public Form1()
  8.         {
  9.             InitializeComponent();
  10.         }
  11.         /// <summary>
  12.         /// 选择文件
  13.         /// </summary>
  14.         /// <param name="sender"></param>
  15.         /// <param name="e"></param>
  16.         private void button1_Click(object sender, EventArgs e)
  17.         {
  18.             OpenFileDialog openFileDialog1 = new OpenFileDialog();
  19.             openFileDialog1.Multiselect = true;
  20.             openFileDialog1.Title = "请选择文件";
  21.             openFileDialog1.Filter = "所有文件(*.*)|*.*";
  22.             if (openFileDialog1.ShowDialog() == DialogResult.OK)
  23.             {
  24.                 string filename = openFileDialog1.FileName;
  25.                 MessageBox.Show("已选择文件:" + filename, "选择文件提示", MessageBoxButtons.OK, MessageBoxIcon.Information);
  26.             }
  27.         }
  28.         /// <summary>
  29.         /// 选择文件夹、路径
  30.         /// </summary>
  31.         /// <param name="sender"></param>
  32.         /// <param name="e"></param>
  33.         private void button2_Click(object sender, EventArgs e)
  34.         {
  35.             FolderBrowserDialog folderBrowserDialog1 = new FolderBrowserDialog();
  36.             folderBrowserDialog1.Description = "请选择文件路径";
  37.             if (folderBrowserDialog1.ShowDialog() == DialogResult.OK)
  38.             {
  39.                 string path = folderBrowserDialog1.SelectedPath;
  40.                 MessageBox.Show("已选择文件夹:" + path, "选择文件夹提示", MessageBoxButtons.OK, MessageBoxIcon.Information);
  41.             }
  42.         }
  43.         /// <summary>
  44.         /// 打开目录
  45.         /// </summary>
  46.         /// <param name="sender"></param>
  47.         /// <param name="e"></param>
  48.         private void button3_Click(object sender, EventArgs e)
  49.         {
  50.             System.Diagnostics.Process.Start("Explorer.exe", "C:\\Windows");
  51.         }
  52.     }
  53. }
复制代码
感谢楼主无私分享!
发表于 2021-9-12 15:43:12 | 显示全部楼层
发表于 2025-11-24 19:41:49 | 显示全部楼层
发表于 2025-11-24 19:59:54 | 显示全部楼层
发表于 2025-11-24 20:02:57 | 显示全部楼层
发表于 2025-11-24 20:03:21 | 显示全部楼层
发表于 2025-11-24 20:04:46 | 显示全部楼层
发表于 2025-11-24 20:07:58 | 显示全部楼层
发表于 2025-11-24 20:10:41 | 显示全部楼层
GMT+8, 2025-12-22 20:16 , Processed in 0.193732 second(s), 26 queries .
