![]() 1. PLC 可编程逻辑控制器 2. absolute 绝对位置 3. absoluteoutput 绝对输出 4 .actuator 执行器/作动器 5. against 对比 6. allocate 分配 7. alter 改变/修改 8. ambient 环境周围 ambient operating temperature 9. analog 模拟 analogoutput 10. analysis 分析 thecollection an and analysis of data 12. applicable 可用 the applicableCPU for the module 13. assign 分配 14. back up battey 备用电池 15. barcode reader/ID 条形码阅读器 16. base unit 主基板 17. baud 波特 18. beforehand 事先 19. binary 二进制 20. buffer memory 缓冲存储器 21. bus 总线 22. case 外壳 do notremove the module's print board from the case 23. characteristic 特征 I/Ocharacterristic 24. check 校验 the datalink status canbe checked 25. child-station 子站 26. common terminal 公共端 27. compatible 兼容 compatiblewith the MODBUS protocol 28. compound 混合 compoundsystem communication 29. condensation 结露 30. condition 条件 conditionsetting 31. conductive 导电 conductivemetal picees 32. configuration 组态 systemconfiguration 33. configure 组态 34. confirm 确认how toconfirm the operation of the module 35. consumption 消耗 currentconsumption 36. content 目录 37. control level 控制级 38. convenient 方便 moreconvenient and easy-to-use 39. conventionaly 传统 whichconventionaly has been used 40. conversion 转换 Analog-Digital conversion module 41. converter 转换器 42. conveyor 传送 conveyorline 43. corrosive 腐蚀 corrosivegas 44. countermeasure 对策 countermeasure for mis-inpute 45. cutoff 切断 46. debug 调试 isrecommended before debugging 47. dedicated 屏蔽 cc-linkdedicated cable 48. dedicated 专用 dedicatedtransmission protocol 49. default value 缺省值 50. define 解释/阐明 Offset value and gain value are defined as follow. 51. design 设计 design asystem 52. device level 现场级 53. diagnosis 诊断 diagnosisfunction 54. digital 数字 digitalinpute 55. DIN rail 导轨 56. diverse 不同的/各种各样的 57. download 下载 58. duplicate 完全一样 59. dust 灰尘 60. eliminate 免得 61. enterprise level 管理级 62. erase 清除 63. exceed 超出The numberadmitted must not exceed 200 64.execute 执行date linkis executed using these parameters 65. expand 扩展 can beeapanded up to 255 networks 66. faulty 故障站 67. field bus 现场总线 68. fix 固定 69. flexibly 灵活的 to supporta variety systerm flexibly 70. flow 流量 71. format 格式 transmission format 72. fuse 融丝 73.graph图标坐标图曲线voltage output characterristicgraph 74.guaranteed 担保nomaloperration cannot be guaranteed 75. handle 处理 76. hardware manual 硬件手册 77. hint 提示 programminghints 78. humidity 湿度 ambientoperating humdlity 79. individual 独立的 80. inductance 电感 inductanceload 81. initiate 实施发起 can be initiate by a computer [i`nifieit] 82. input 输入 83. input point 输入点数 84. install 安装 85. instruction 指令 the FROMinstruction 86. insulation 隔离 form rubberprovides good insulation 87. interface 接口88.interlocking 互锁can be usedfor sequence program interlocking 89. internal external 内部 外部 internal connection 90. interrupt 中断 excute aninterrupt processing 91. invalid 无效 errorinvalid station function 92. magnetic 有磁性的 magneticfields [maeg`netik] 93. main circuit 主回路/线电路 94. malfunction 故障 causesystem malfunction 95. mandatory 强制 96. mantenance 维护 maintenancecosts are reduced 97. manual 手册 User'Manual 98. mechanical 机械 michanicallife 机械寿命 99. module 模块/组件 mount orremove the module 100. momentary power failure 瞬时断电 101. monitor 监视 102. mount 固定 mount orremove the module 103. multiple 多样 mutipleremote i/o modules 104. negative 负 105. observation 观察 106. occupy 占用 occupies 1station 107. occur 发生 108. offline 离线 offlinetest 109. offset gain 偏置增益 110. oil mist 油雾 112. optical loop 光缆回路 113. optimum 最佳的 optimumcontrol 114. output 输出 115. overall 总的 overalldistance 116. overview 总揽 communication overview 117. parameter 参数 118. path 路径 transmission path 119. per network 120. perform 进行 normal datalink cannot be performed 121. performance specifations 性能规格 122. peripheral 外围/外部设备 Whenutilizing peripheral device to assign I/O number. 123. phase 相 swith offall phases of the power supply 124. point 要点 125. port 接口 Rs232c port 126. positive 正 127.power line 电源线 128. power on/off 电源开/关 129.precaution 注意事项precaution when configuing system 130. print board 印刷电路板 131. procedure 过程 follow theprocedure 132. programing interface 编程接口/编程界面 133. protocol 协议 protocolcommunication issues 134. range 范围 135. rated input voltage 额定输入电压 136. ratio 比率 137. recommend 建议 isrecommended before debugging 138. reduce 减少/缩小 the numberof steps in operation program can be reduced 139. refer to 参照 refer toChapter 6 140. register 数据寄存器 141. relay 继电器 142. remote I/O 远程网络 143. reserved station 预留主站 144. resistor 电阻器 load bridgingresistor 负载转移电阻 load compensating resistor 负荷补偿电阻 load shifting resistor 负载移动电阻器 ; 负荷转移电阻 load-resistor contactor 负载电阻器接触器 ; 负荷电阻接触器 anode load resistor 释义阳极负载电阻 ; 阳极负载电阻 effect of load resistor 负载电阻效应 145. resolution 分辨率 nMaximum resolution 最大分辨率 146. restriction 限制 norestriction [ri`strikfn] 147. retry 重试 148. scan 扫描 link scan 149. screw 螺丝 Teminal-block screw 150. seamless network 无缝网络 151. sequence programme 顺控程序 152. serial communications module 串口通信模块 153. series 系列 154. servo 伺服系统 155. short 短路 156. signal 信号 157. sink 漏极 sink commen 158. slot 周边元件扩展插槽 159. soures 源极 sourescommen 160. specifications 特性 inputmodules specifications 161. stabilized power supply 稳压电源 162. standby master station 备用主站 163. start up 起动 164. status 状态 data linkstatus 165. step drive 步进 166. storage 存储 storagearea 167. store 存储 168. switch off 切断 swith offall phases of the power supply 169. swith 开关 170. table 表格 171. transfer 传送 172. transistor 晶体管 173. transmission speed 传输速度 174. transmit 传送/传输 data istransmitted in unchanged code 175. triac 三端双向可控硅开关元件 176. troubleshooting 故障处理 177. unuseble 不可以使用 178. upload 上传/上载 179. utilize 利用 180. verify 校验 verify theset parameter contents 181. voltage 电压 highvoltage 182. watchdog 看门狗定时器 183. width 范围 184. wire chips 线头 ![]() |
( 沪ICP备14007696号-3 )|网站地图
GMT+8, 2019-3-23 09:41 , Processed in 0.031518 second(s), 30 queries .
