查看: 2579|回复: 13
Winform 限制窗体只能在屏幕内, 不能拖拽到屏幕外面
发表于 2021-8-19 19:27:44 | 显示全部楼层 |阅读模式
添加一个类文件"BaseForm.cs"
代码如下:
using System;
using System.Collections.Generic;
using System.Text;
using System.Windows.Forms;
using System.Drawing;
using System.Runtime.InteropServices;
namespace WindowsFormsApp3
    public class BaseForm : Form
        private Point _mouseDownPos;
        private bool _move;
        protected override void WndProc(ref Message m)
            RECT nativeRect;
            switch (m.Msg)
                case 0x20:
                    int lp = m.LParam.ToInt32();
                    if ((lp & 0xFFFF) == 2 &&
                    ((lp >> 0x10) & 0xFFFF) == 0x201)
                        _mouseDownPos = Control.MousePosition;
                        _move = true;
                    break;
                case 0x231:
                    if (_move)
                        Rectangle rect = Screen.GetWorkingArea(this);
                        nativeRect = new RECT(
                         _mouseDownPos.X - Location.X,
                         _mouseDownPos.Y - Location.Y,
                         rect.Right - (Bounds.Right - _mouseDownPos.X),
                         rect.Bottom - (Bounds.Bottom - _mouseDownPos.Y));
                        ClipCursor(ref nativeRect);
                    break;
                case 0x0232:
                    if (_move)
                        nativeRect = new RECT(Screen.GetWorkingArea(this));
                        _move = false;
                    break;
            base.WndProc(ref m);
        [DllImport("user32.dll")]
        public static extern bool ClipCursor(ref RECT lpRect);
        [StructLayout(LayoutKind.Sequential)]
        public struct RECT
            public int Left;
            public int Top;
            public int Right;
            public int Bottom;
            public RECT(int left, int top, int right, int bottom)
                Left = left;
                Top = top;
                Right = right;
                Bottom = bottom;
            public RECT(Rectangle rect)
                Left = rect.Left;
                Top = rect.Top;
                Right = rect.Right;
                Bottom = rect.Bottom;
            public Rectangle Rect
                get
                    return new Rectangle(
                    Left,
                    Top,
                    Right - Left,
                    Bottom - Top);
            public Size Size
                get
                    return new Size(Right - Left, Bottom - Top);
            public static RECT FromXYWH(int x, int y, int width, int height)
                return new RECT(x,
                  y,
                  x + width,
                  y + height);
            public static RECT FromRectangle(Rectangle rect)
                return new RECT(rect.Left,
                   rect.Top,
                   rect.Right,
                   rect.Bottom);
新建应用窗体"Form1.cs",继承"BaseForm"
public partial class Form1 : BaseForm
    public Form1()
        InitializeComponent();
调试运行,窗体只能在屏幕内部来回拖动,无法拖拽到屏幕外。
​来源:C#社区
发表于 2021-8-19 19:53:42 | 显示全部楼层
  • 打卡等级:无名新人
  • 打卡总天数:1
  • 打卡总奖励:6
  • 最近打卡:2025-01-22 14:08:01
QQ
发表于 2021-8-20 09:46:23 | 显示全部楼层
书山有路勤为径
发表于 2025-11-18 18:30:05 | 显示全部楼层
发表于 2025-11-18 18:34:45 | 显示全部楼层
发表于 2025-11-18 18:36:04 | 显示全部楼层
发表于 2025-11-18 18:36:21 | 显示全部楼层
发表于 2025-11-18 18:37:37 | 显示全部楼层
发表于 2025-11-18 18:39:14 | 显示全部楼层
GMT+8, 2025-12-22 12:58 , Processed in 0.495312 second(s), 27 queries .
