查看: 861|回复: 10
MOS管输入电阻很高,为什么一遇到静电就不行
发表于 2024-7-15 16:53:21 | 显示全部楼层 |阅读模式
01
MOS管输入电阻很高,为什么一遇到静电就不行了?
MOS管一个ESD敏感器件,它本身的输入电阻很高,而栅-源极间电容又非常小,所以极易受外界电磁场或静电的感应而带电,又因在静电较强的场合难于泄放电荷,容易引起静电击穿。
静电击穿一般分为两种类型:
  • 电压型,即栅极的薄氧化层发生击穿,形成针孔,使栅极和源极间短路,或者使栅极和漏极间短路;
  • 功率型,即金属化薄膜铝条被熔断,造成栅极开路或者是源极开路。
03
MOS栅源(G-S)极下拉电阻有什么作用?
‍MOS是电压驱动元件,对电压很敏感,悬空的G很容易接受外部干扰使MOS导通,外部干扰信号对G-S结电容充电,这个微小的电荷可以储存很长时间。
在试验中G悬空很危险,很多就因为这样爆管,G接个下拉电阻对地,旁路干扰信号就不会直通了,一般可以10~20K。这个电阻称为栅极电阻。
  • 作用1:为场效应管提供偏置电压;
  • 作用2:起到泻放电阻的作用(保护栅极G~源极S)。
第一个作用好理解,这里解释一下第二个作用的原理。保护栅极G~源极S,场效应管的G-S极间的电阻值是很大的,这样只要有少量的静电就能使他的G-S极间的等效电容两端产生很高的电压。
如果不及时把这些少量的静电泻放掉,他两端的高压就有可能使场效应管产生误动作,甚至有可能击穿其G-S极。这时栅极与源极之间加的电阻就能把上述的静电泻放掉,从而起到了保护场效应管的作用。
https://weibo.com/7931859757/OmW9tnvJb
https://weibo.com/7932047597/OmWlId1rJ
https://weibo.com/7932047597/OmWnNvK8i
https://weibo.com/7932047597/OmWpNB0Bz
https://weibo.com/7932047597/OmWrtlj6k
https://weibo.com/7932047597/OmWtAnd3v
https://weibo.com/7932047597/OmWwbrZsG
https://weibo.com/7932047597/OmWy2dMPg
https://weibo.com/7932047597/OmWzRvPyT
https://weibo.com/7932047597/OmWBYurUp
https://weibo.com/7932047597/OmWEcrVq2
https://weibo.com/7929311887/OmVHau3b7
https://weibo.com/7929311887/OmVLwq0mf
https://weibo.com/7929311887/OmVNYhVLT
https://weibo.com/7929311887/OmVPHpUIx
https://weibo.com/7929311887/OmVRt2Dou
https://weibo.com/7929311887/OmVYiqE3L
https://weibo.com/7929311887/OmVZM6h1D
https://weibo.com/7929311887/OmW1L9v3h
https://weibo.com/7929311887/OmW3ACwKj
https://weibo.com/7929311887/OmW6e8Is5
https://weibo.com/7929311887/OmW9toCek
https://weibo.com/7929311887/OmWbHDHkc
https://weibo.com/7929311887/OmWcGqyuH
https://weibo.com/7929311887/OmWfIt9LL
https://weibo.com/7929311887/OmWir6eTy
https://weibo.com/7929311887/OmWlM5LGh
https://weibo.com/7929311887/OmWnV0KQ9
https://weibo.com/7929311887/OmWpQEV6B
https://weibo.com/7929311887/OmWrwaUcz
https://weibo.com/7929311887/OmWtA6I4v
https://weibo.com/7929311887/OmWweFNsr
https://weibo.com/7929311887/OmWy2wub2
https://weibo.com/7929311887/OmWC14EYV
https://weibo.com/7929311887/OmWEeDIV3
https://m.weibo.cn/detail/5053898916367104
https://m.weibo.cn/detail/5053897492139159
https://m.weibo.cn/detail/5053896741618183
https://m.weibo.cn/detail/5053895078577475
https://m.weibo.cn/detail/5053893744527981
https://m.weibo.cn/detail/5053892465529112
https://m.weibo.cn/detail/5053891192555913
https://m.weibo.cn/detail/5053890377288802
https://m.weibo.cn/detail/5053888954895386
https://m.weibo.cn/detail/5053887629234301
https://m.weibo.cn/detail/5053886341843752
https://m.weibo.cn/detail/5053884919714695
https://m.weibo.cn/detail/5053883728003711
https://m.weibo.cn/detail/5053881908201082
https://m.weibo.cn/detail/5053880432332927
https://m.weibo.cn/detail/5053879094351334
发表于 2025-11-12 17:10:37 | 显示全部楼层
发表于 2025-11-12 17:23:29 | 显示全部楼层
发表于 2025-11-12 18:46:40 | 显示全部楼层
发表于 2025-11-14 05:35:09 | 显示全部楼层
发表于 2025-11-14 06:21:28 | 显示全部楼层
发表于 2025-11-18 16:27:55 | 显示全部楼层
发表于 2025-11-18 17:34:34 | 显示全部楼层
发表于 2025-11-19 01:15:41 | 显示全部楼层
发表于 2025-11-19 13:59:24 | 显示全部楼层
GMT+8, 2025-12-22 20:21 , Processed in 0.476895 second(s), 25 queries .
