工控课堂 首页 工控文库 上位机编程 查看内容
MSVC2019的vector标准库实现源码分析
2022-6-27 21:39| 发布者: 198366809| 查看: 735| 评论: 0
摘要: 好记性不如烂博客;stl源码剖析那本书不想看,没事(有事懒得做)看看微软的vector实现。以vectorint 为例template class _Ty, class _Alloc = allocator_Ty class vector { // varying size array of values privat ...
以vector<int> 为例
复制代码
template <class _Ty, class _Alloc = allocator<_Ty>>
private:
    template <class>
    friend class _Vb_val;//????
    friend _Tidy_guard<vector>;
    using _Alty        = _Rebind_alloc_t<_Alloc, _Ty>;//会区分是不是默认分配器_Default_allocator_traits或自定义allocator,是默认的话,就是本身allocator<int>,否则。。。模板嵌套太多了。。
    using _Alty_traits = allocator_traits<_Alty>;
public:
    static_assert(!_ENFORCE_MATCHING_ALLOCATORS || is_same_v<_Ty, typename _Alloc::value_type>,
        _MISMATCHED_ALLOCATOR_MESSAGE("vector<T, Allocator>", "T"));
    using value_type      = _Ty;//int
    using allocator_type  = _Alloc;//
    using pointer         = typename _Alty_traits::pointer;
    using const_pointer   = typename _Alty_traits::const_pointer;
    using reference       = _Ty&;
    using const_reference = const _Ty&;
    using size_type       = typename _Alty_traits::size_type;
    using difference_type = typename _Alty_traits::difference_type;
private:
//template <class _Alloc> // tests if allocator has simple addressing
  //_INLINE_VAR constexpr bool _Is_simple_alloc_v = is_same_v<typename allocator_traits<_Alloc>::size_type, size_t>&&
  //is_same_v<typename allocator_traits<_Alloc>::difference_type, ptrdiff_t>&&
  //is_same_v<typename allocator_traits<_Alloc>::pointer, typename _Alloc::value_type*>&&
  //is_same_v<typename allocator_traits<_Alloc>::const_pointer, const typename _Alloc::value_type*>;
using _Scary_val = _Vector_val<conditional_t<_Is_simple_alloc_v<_Alty>, _Simple_types<_Ty>,
        _Vec_iter_types<_Ty, size_type, difference_type, pointer, const_pointer, _Ty&, const _Ty&>>>;//是否是simple类型,选择不同的types,
      只要不是自定义类型,应该都是选择第一个,其实第二个无非也是用自定义的类型。
public: using iterator = _Vector_iterator<_Scary_val>; using const_iterator = _Vector_const_iterator<_Scary_val>; using reverse_iterator = _STD reverse_iterator<iterator>; using const_reverse_iterator = _STD reverse_iterator<const_iterator>;
  //两个构造函数同理,区分自定义分配器类型 #define _GET_PROXY_ALLOCATOR(_Alty, _Al) static_cast<_Rebind_alloc_t<_Alty, _Container_proxy>>(_Al) 这种写法第一次见,参数没有实际作用,构造一个新对象 _CONSTEXPR20_CONTAINER vector() noexcept(is_nothrow_default_constructible_v
<_Alty>) : _Mypair(_Zero_then_variadic_args_t{}) { _Mypair._Myval2._Alloc_proxy(_GET_PROXY_ALLOCATOR(_Alty, _Getal()));//_GET_PROXY_ALLOCATOR(_Alty, _Getal()),构造一个allocator<_Container_proxy>
_CONSTEXPR20_CONTAINER explicit vector(const _Alloc& _Al) noexcept : _Mypair(_One_then_variadic_args_t{}, _Al) { _Mypair._Myval2._Alloc_proxy(_GET_PROXY_ALLOCATOR(_Alty, _Getal())); }
  _Compressed_pair<_Alty, _Scary_val> _Mypair;//仅有的成员变量,实际继承第一个模板参数,负责分配数据内存,并持有一个_Scary_val的变量,负责管理数据
复制代码
 可以看到这些都涉及到了大量的模板元编程。先看下_Compressed_pair是什么,有两个模板参数_Alty, _Scary_val,第一个已经知道是什么了allocator<int>, 第二个呢?是一个_Vector_val类型。基本看出这个类型才是真正的数据载体以及维护者
复制代码
class _Vector_val : public _Container_base {// 基类里有个_Container_proxy* _Myproxy,维护迭代器的一个东西。
public:
    using value_type      = typename _Val_types::value_type;
    using size_type       = typename _Val_types::size_type;
    using difference_type = typename _Val_types::difference_type;
    using pointer         = typename _Val_types::pointer;
    using const_pointer   = typename _Val_types::const_pointer;
    using reference       = value_type&;
    using const_reference = const value_type&;
    _CONSTEXPR20_CONTAINER _Vector_val() noexcept : _Myfirst(), _Mylast(), _Myend() {}
    _CONSTEXPR20_CONTAINER _Vector_val(pointer _First, pointer _Last, pointer _End) noexcept
        : _Myfirst(_First), _Mylast(_Last), _Myend(_End) {}
    _CONSTEXPR20_CONTAINER void _Swap_val(_Vector_val& _Right) noexcept {
        this->_Swap_proxy_and_iterators(_Right);
        _Swap_adl(_Myfirst, _Right._Myfirst);
        _Swap_adl(_Mylast, _Right._Mylast);
        _Swap_adl(_Myend, _Right._Myend);
    _CONSTEXPR20_CONTAINER void _Take_contents(_Vector_val& _Right) noexcept {
        _Myfirst = _Right._Myfirst;
        _Mylast  = _Right._Mylast;
        _Myend   = _Right._Myend;
        _Right._Myfirst = nullptr;
        _Right._Mylast  = nullptr;
        _Right._Myend   = nullptr;
    pointer _Myfirst; // pointer to beginning of array 指针维护数据结构
    pointer _Mylast; // pointer to current end of sequence
    pointer _Myend; // pointer to end of array
复制代码
再接着看_Compressed_pair,目前标准容器库的实现大致都是这样的模式。实际是继承第一个模板参数,那么本身就是一个分配器。并持有一个_Vector_val 的变量。基本所有的东西都齐全了,第一个参数分配数据,第二个模板参数管理数据。
复制代码
template <class _Ty1, class _Ty2, bool = is_empty_v<_Ty1> && !is_final_v<_Ty1>>
class _Compressed_pair final : private _Ty1 { // store a pair of values, deriving from empty first
public:
    _Ty2 _Myval2;
    using _Mybase = _Ty1; // for visualization
    template <class... _Other2>
    constexpr explicit _Compressed_pair(_Zero_then_variadic_args_t, _Other2&&... _Val2) noexcept(//标签派发
        conjunction_v<is_nothrow_default_constructible<_Ty1>, is_nothrow_constructible<_Ty2, _Other2...>>)
        : _Ty1(), _Myval2(_STD forward<_Other2>(_Val2)...) {}
    template <class _Other1, class... _Other2>
    constexpr _Compressed_pair(_One_then_variadic_args_t, _Other1&& _Val1, _Other2&&... _Val2) noexcept(
        conjunction_v<is_nothrow_constructible<_Ty1, _Other1>, is_nothrow_constructible<_Ty2, _Other2...>>)
        : _Ty1(_STD forward<_Other1>(_Val1)), _Myval2(_STD forward<_Other2>(_Val2)...) {}
    constexpr _Ty1& _Get_first() noexcept {
        return *this;//返回分配器,就是自身
    constexpr const _Ty1& _Get_first() const noexcept {
        return *this;
复制代码
 现在来看具体的构造过程,在构造函数里都有Alloc_proxy函数,看它的实现
复制代码
    _CONSTEXPR20_CONTAINER void _Alloc_proxy(_Alloc&& _Al) {//注意此时的_Al 是 allocator<container_proxy>,因为重新生成了一个allocator,具体看上面的_GET_PROXY_ALLOCATOR
_Container_proxy* const _New_proxy = _Unfancy(_Al.allocate(1));//分配一个container_proxy的内存16个字节,因为有两个指针,
_Construct_in_place(*_New_proxy, this);//为刚才分配的内存,调用构造函数
 _Myproxy = _New_proxy;
_New_proxy
->_Mycont = this;//互相记录,container_base 记录一个proxy,这个proxy记录一个my_cont(container_base)
复制代码
这个应该是维护迭代器的,目前只是初始化完成。接着看下vector的push_back操作,因为push_back内部操作还是调用了emplace_back。区分了左值和右值的参数调用。
复制代码
template <class... _Valty>
    _CONSTEXPR20_CONTAINER decltype(auto) emplace_back(_Valty&&... _Val) {
        // insert by perfectly forwarding into element at end, provide strong guarantee
        auto& _My_data   = _Mypair._Myval2;
        pointer& _Mylast = _My_data._Mylast;
        if (_Mylast != _My_data._Myend) {//last!=end 可以理解为capacity大于size,利用已有的多余内存构建数据。
            return _Emplace_back_with_unused_capacity(_STD forward<_Valty>(_Val)...);
        _Ty& _Result = *_Emplace_reallocate(_Mylast, _STD forward<_Valty>(_Val)...);//新分配内存
#if _HAS_CXX17
        return _Result;
#else // ^^^ _HAS_CXX17 ^^^ // vvv !_HAS_CXX17 vvv
        (void) _Result;
#endif // _HAS_CXX17
复制代码
 vector的内存分配方式,大多网上都有讲,这里具体看下采用什么样的内存分配策略。
复制代码
    _CONSTEXPR20_CONTAINER pointer _Emplace_reallocate(const pointer _Whereptr, _Valty&&... _Val) {
        // reallocate and insert by perfectly forwarding _Val at _Whereptr
        _Alty& _Al        = _Getal();
        pointer& _Myfirst = _My_data._Myfirst;
        _STL_INTERNAL_CHECK(_Mylast == _My_data._Myend); // check that we have no unused capacity
        const auto _Whereoff = static_cast<size_type>(_Whereptr - _Myfirst);//whereptr代表放入数据的位置
        const auto _Oldsize  = static_cast<size_type>(_Mylast - _Myfirst);//当前的size大小
        if (_Oldsize == max_size()) {
            _Xlength();//数据太大
        const size_type _Newsize     = _Oldsize + 1;//已有的数据上新加一个
        const size_type _Newcapacity = _Calculate_growth(_Newsize);
        /*核心部分*/
_CONSTEXPR20_CONTAINER size_type _Calculate_growth(const size_type _Newsize) const {
    // given _Oldcapacity and _Newsize, calculate geometric growth
    const size_type _Oldcapacity = capacity();
    const auto _Max = max_size();
    if (_Oldcapacity > _Max - _Oldcapacity / 2) {
      return _Max; // geometric growth would overflow
    const size_type _Geometric = _Oldcapacity + _Oldcapacity / 2;//在旧的大小基础上加一半,1 , 2, 3 ,4,5, 7增长方式,前几个每次都会重新分配内存,
    if (_Geometric < _Newsize) {
      return _Newsize; // geometric growth would be insufficient
    return _Geometric; // geometric growth is sufficient 返回的大小一定大于等于newsize
    const pointer _Newvec = _Al.allocate(_Newcapacity);
const pointer _Constructed_last = _Newvec + _Whereoff + 1;
        pointer _Constructed_first      = _Constructed_last;
        _TRY_BEGIN
        _Alty_traits::construct(_Al, _Unfancy(_Newvec + _Whereoff), _STD forward<_Valty>(_Val)...);//在新分配的内存里,构建新加入的数据
        _Constructed_first = _Newvec + _Whereoff;
        if (_Whereptr == _Mylast) { // at back, provide strong guarantee
            _Umove_if_noexcept(_Myfirst, _Mylast, _Newvec);//将旧数据移动到新的内存里。
        } else { // provide basic guarantee
            _Umove(_Myfirst, _Whereptr, _Newvec);
            _Constructed_first = _Newvec;
            _Umove(_Whereptr, _Mylast, _Newvec + _Whereoff + 1);
        _CATCH_ALL
        _Destroy(_Constructed_first, _Constructed_last);//异常捕捉
        _Al.deallocate(_Newvec, _Newcapacity);
        _RERAISE;
        _CATCH_END
        _Change_array(_Newvec, _Newsize, _Newcapacity);//因为容器重分配内存,需要重新调整,first,last,end指针,同时让所有的迭代器失效
        return _Newvec + _Whereoff;
复制代码
上面是重新分配数据的逻辑,如果capacity较大时,则会在已有的内存上构建数据。
复制代码
    _CONSTEXPR20_CONTAINER decltype(auto) _Emplace_back_with_unused_capacity(_Valty&&... _Val) {
        _STL_INTERNAL_CHECK(_Mylast != _My_data._Myend); // check that we have unused capacity
        _Alty_traits::construct(_Getal(), _Unfancy(_Mylast), _STD forward<_Valty>(_Val)...);
        _Orphan_range(_Mylast, _Mylast);//使迭代器失效
        _Ty& _Result = *_Mylast;
        ++_Mylast;
#if _HAS_CXX17
        return _Result;
        (void) _Result;
复制代码
关于迭代器的问题,是由container_proxy管理的,当创建一个迭代器的时候,调用如下函数,proxy记录相关信息
复制代码
_CONSTEXPR20_CONTAINER void _Adopt_unlocked(const _Container_base12* _Parent) noexcept {
        if (!_Parent) {
            _Orphan_me_unlocked_v3();
            return;
        _Container_proxy* _Parent_proxy = _Parent->_Myproxy;
        if (_Myproxy != _Parent_proxy) { // change parentage
            if (_Myproxy) { // adopted, remove self from list
            _Mynextiter                 = _Parent_proxy->_Myfirstiter;//每次adopt,proxy记录的迭代器都会更新为当前,把上一个记录在_Mynextiter里,形成一个chain
            _Parent_proxy->_Myfirstiter = this;
            _Myproxy                    = _Parent_proxy;//当一个迭代器的_Myproxy为空时,即为失效,比如push_back后,end()迭代器就会失效
复制代码
具体可以看源码,看看在那些地方调用了orphan_range操作。关键部分大概就是这样了,详细的细节看下源码应该问题不大。
复制代码
struct _Default_allocator_traits { // traits for std::allocator
    using value_type     = typename _Alloc::value_type;
    using pointer            = value_type*;
    using const_pointer      = const value_type*;
    using void_pointer       = void*;
    using const_void_pointer = const void*;
    using size_type       = size_t;//默认的size_t
    using difference_type = ptrdiff_t;
    using propagate_on_container_copy_assignment = false_type;
    using propagate_on_container_move_assignment = true_type;
    using propagate_on_container_swap            = false_type;
    using is_always_equal                        = true_type;
    template <class _Other>
    using rebind_alloc = allocator<_Other>;
    using rebind_traits = allocator_traits<allocator<_Other>>;
复制代码
GMT+8, 2025-12-23 08:21 , Processed in 0.417441 second(s), 23 queries .
